smallest 0603 cap...
J
John Larkin
I need a tiny cap.
This one is interesting
https://www.mouser.com/ProductDetail/Walsin/RF03N0R1B100CT?qs=sGAEpiMZZMvsSlwiRhF8qtsBU8Zhqm2Ra%2Fa5698GTEQZP2uSIBTS%2FQ%3D%3D
Below 0.1 pF, maybe I can use a 10 meg resistor, which is around 0.04
pF. Maybe a couple in series? Maybe a network?
John Larkin wrote:
I need a tiny cap.
I have some 0.1 pF caps in stock too, primarily for adjusting the
transfer functions of high-Z TIAs.
You could maybe make a poor man\'s 3-terminal cap using two of those in
series--the capacitance to ground from the midpoint would reduce the
end-to-end capacitance.
Cheers
Phil Hobbs
Dr Philip C D Hobbs
Principal Consultant
ElectroOptical Innovations LLC / Hobbs ElectroOptics
Optics, Electro-optics, Photonics, Analog Electronics
Briarcliff Manor NY 10510
http://electrooptical.net
http://hobbs-eo.com
On Tue, 24 Jan 2023 13:41:52 -0500, Phil Hobbs
<pcdhSpamMeSenseless@electrooptical.net> wrote:
John Larkin wrote:
I need a tiny cap.
Cheers
Phil Hobbs
One end of my cap will be ground already.
I could just use PCB capacitance, but that\'s hard to tune. I\'d just
have to get it right first try.
On Tuesday, January 24, 2023 at 12:47:09 PM UTC-8, Phil Hobbs wrote:
It\'s already not that easy to get less than 0.1 pF to ground from a PCB
pad, let alone a trace.
Yeah, but the usual trim techniques still work; RG174 is 30 pF/foot,
so you can get your 0.1 pf by soldering a short length onto the board, and then
with flush nippers, cut it off.
0.04 inches for 0.1 pf. How does that work exactly?
Rick C.
- Get 1,000 miles of free Supercharging
- Tesla referral code - https://ts.la/richard11209
... the usual trim techniques still work; RG174 is 30 pF/foot,
That\'s why it takes flush nippers. :)
pcdhSpamM...@electrooptical.net> wrote:
John Larkin wrote:
I need a tiny cap.
Cheers
Phil Hobbs
Yes, but when you look at the tolerances are you really gaining much?
John
Am 24.01.23 um 19:41 schrieb Phil Hobbs:
John Larkin wrote:
I need a tiny cap.
That\'s why ADS or other CAD systems have these capacitor-less
capacitors with interdigitated layout models that can be tuned
with a scalpell if really needed on the hardware board.
A 0201 cap that swims around during soldering?
> Cheers
Gerhard
I invite you to try getting the fringing capacitance of an actual piece
of RG-174, connected to a circuit, to be that low. Show your work. ;)
(The capacitance per unit length only applies when the fringing
capacitance is negligible.)
Cheers
Phil Hobbs
But, because this is a trimming technique, there\'s an end correction BEFORE the
snip as well as after. At least, there is until the two ends of the cable coincide...
I\'m not concerned with high frequencies much, so I might apply a negative capacitor
first, swamp it with the long-RG174 trimmer, then trim down to get near zero. Negative
impedance converter, you know...
<https://wiki.analog.com/university/courses/electronics/text/chapter-4>
On a sunny day (Tue, 24 Jan 2023 10:37:01 -0800) it happened John Larkin
<jlarkin@highlandSNIPMEtechnology.com> wrote in
<n390th9l7dkb25tai5g3aj4cesoe6n0u5u@4ax.com>:
I need a tiny cap.
LOL looks like a type by them
value .1 pF
tolerane .1 pF
multilayer???
LOL
likely 100 nF!
At 10V must be!
On a sunny day (Tue, 24 Jan 2023 11:17:06 -0800) it happened John Larkin
<o5b0thlfg6oiep66l7om8tcnns6hldcbfq@4ax.com>:
John Larkin wrote:
I need a tiny cap.
Cheers
Phil Hobbs
Bended wire, twisted wire...
done it.
I need a tiny cap.
value .1 pF
tolerane .1 pF
multilayer???
LOL
likely 100 nF!
At 10V must be!
So, even if it is really .1 pF the capacitance between the soldering masses at the ends will change that!
It seems that sort of stuff (and I joked about that a while back here)
is sold to clueless Spice users who never build a RF circuit and
are now looking for .1 pF ??? SMDs
How many THz and what sort of peeseebee they use?
What a crap world of snake oil sellers
Reminds me of the F35, likely also spice designed...
My predictions come true, US military now goes
for nuculear space propulsion, pick up where they
left in the sixties....
https://www.rt.com/news/570435-nasa-darpa-nuclear-mars/
Well, nothing to worry about, anything metal floating next to it will detune its .001 pF peeseebees.
If they even can get it of the ground.
2 drops of solder.. add more when needed, better is to design a circuit that does not need .1 pF caps.
o o
0 0
<0>
| cookie
jla...@highlandSNIPMEtechnology.com> wrote in
n390th9l7dkb25tai...@4ax.com>:
I need a tiny cap.
value .1 pF
tolerane .1 pF
multilayer???
LOL
likely 100 nF!
At 10V must be!
LOL! But the part number matches a 0.1pF, ±0.1pF cap. So they can ship you an empty reel and claim they are within tolerance!
No need for multilayer... no need for any layers!! The un-capacitor!
A friend pointed out once that zero ohm resistors had amazingly tight tolerances, considering they were specified as ±10%, which would be ±0 ohms! That\'s a tough spec to meet. In fact, impossible.
Rick C.
+ Get 1,000 miles of free Supercharging
+ Tesla referral code - https://ts.la/richard11209
o5b0thlfg6oiep66l...@4ax.com>:
John Larkin wrote:
I need a tiny cap.
Cheers
Phil Hobbs
done it.
I don\'t recall what gadget it was in, had such a wire indicated on the silkscreen of the circuit board. Seems a wire was soldered to the board, then bent over to create a capacitor to some other part. The board had a single through hole, and a line toward the part it was to be bent over.
Rick C.
-- Get 1,000 miles of free Supercharging
-- Tesla referral code - https://ts.la/richard11209
I still have a package of 0 Ohm 5% resistors (actually, about 20 mOhm).
The company switched to 1% resistors and discarded all stock of 5% reels.
I saved them from the dumpster, stripped them, and repacked in 1.5x1.5\" ZIP-bags.
Arie
I need a tiny cap.
value .1 pF
tolerane .1 pF
multilayer???
one layer of metal, one layer of alumina, one layer of metal
LOL
likely 100 nF!
At 10V must be!
datasheet says 0.1pf
Jasen.
pǝsɹǝʌǝɹ sʇɥƃᴉɹ ll∀
Yes and no. Given invariant fringing capacitance, changing the length
incrementally does give a nice predictable delta-C. Trombone line is
good that way down at low frequency, for instance.
This is because, in a nice long piece of coax, the E field inside is
purely radial almost everywhere, and any departure from the pure TEM
mode at the ends dies off exponentially, roughly as exp(-2 pi L/r),
where L is the distance from the open end and r is the radius. (That\'s
a consequence of Laplace\'s equation, and is also why perforated metal
makes good electrostatic shielding.)
However, John asked for a small absolute capacitance. A picofarad or so
of end effect doesn\'t fit that bill.
Plus when the coax gets too short, the approximation you\'re relying on
starts getting inaccurate because (a) there are varying axial fields
throughout the length of the coax, and (b) the fields at the two ends
interact.
Cheers
Phil Hobbs
Dr Philip C D Hobbs
http://hobbs-eo.com
On Wed, 25 Jan 2023 05:48:33 GMT, Jan Panteltje <alien@comet.invalid>
John Larkin wrote:
I need a tiny cap.
Cheers
Phil Hobbs
done it.
This used to be called a gimmick capacitor.
..<https://en.wikipedia.org/wiki/Gimmick_capacitor>
Joe Gwinn
On Wed, 25 Jan 2023 07:59:52 -0500, Phil Hobbs
And I want something that can be manufactured, not a hobby fiddle
thing.
Something like this:
https://www.dropbox.com/s/z4vevjyuflm732l/T578_LVDS.jpg?raw=1
It needs extreme CMRR to work. If C1 is just a resistor parasitic, I
can make C2 a bit larger and the CMRR error becomes positive feedback,
which is OK in moderation. High voltage Schmitt trigger.
I could just use a digital isolator to drive the GaN fet, but they are
slow. The modulated ones may add jitter, too.
Of course, detonators probably don\'t care about a bit of jitter.
